TwinTurbo.NET: Nissan 300ZX forum - Something else on checking O2s. Even if they blink >>>
Subject Something else on checking O2s. Even if they blink >>>
Posted by ZUL8TR on December 17, 2009 at 12:24 PM
  This message has been viewed 90 times.
In Reply To o2 sensors - kinda confused with testing posted by pearlzed on December 17, 2009 at 10:19 AM
Message the CEL at least 5 times in 10 seconds at 2000 rpm the voltage variation may still be not be OK. For example a good O2 signal will usually yield about 0.9v at the high and about 0.1 v at the low to average out to about 0.5v. If the voltage variations are closer to the average (0.5v) like 0.6v high and 0.4v low the O2 is weak and should be replaced.
If one of the O2 is weak and the other strong I would replace both. Use OEM units.
When checking voltages only use a digital multi meter.
Consult provides the voltages as a readout.
ZUL8TR in Orlando,FL
